Compiling the U-Boot
Follow the steps below to compile the U-Boot for VisionFive 2.
         Locate to your desired directory to store the U-Boot files. For example, the home
          directory.
        Example:
cd ~ # home directory -
         Download the source code for U-Boot compilation.
git clone https://github.com/starfive-tech/u-boot.git -
         Switch to the code branch by executing the following command:
cd u-boot git checkout -b JH7110_VisionFive2_devel origin/JH7110_VisionFive2_devel git pull -
        Type the following to compile U-Boot under the U-Boot directory.
make <Configuration_File> ARCH=riscv CROSS_COMPILE=riscv64-linux-gnu- make ARCH=riscv CROSS_COMPILE=riscv64-linux-gnu-Tip:Configuration_File: For VisionFive 2, the file is starfive_visionfive2_defconfig.
Result:There will be these 3 files generated after compilation inside the u-boot directory:
- u-boot.bin
 - arch/riscv/dts/starfive_visionfive2.dtb
 - spl/u-boot-spl.bin
Figure 1. Example Output - u-boot.bin
          Figure 2. Example Output - visionfive2.dtb
          Figure 3. Example Output - u-boot-spl.bin
          Tip: Both starfive_visionfive2.dtb and u-boot.bin will be used later for OpenSBI compilation.Tip: u-boot-spl.bin will be used later for creating SPL file.
